bad clutch??
Old Apr 12, 2006 | 10:49 PM
FastNeon84's Avatar
FastNeon84
Default bad clutch??
how can u tell when your clutch is about to go bad on you?
Old Apr 13, 2006 | 01:11 AM
spudsterier's Avatar
spudsterier
Default RE: bad clutch??
an easy way is if you go about 40-50 mph in 4th gear and then floor it....if the clutch is goin bad then you will hear the motor rev up before it really startes movin....or if you have a tach then you can keep an eye on it and hit the gas..and see if it increases with the sound of the motor or faster.....and if you have to let out the clutch pedal almost all the way in order for the gear to catch then that could be a sign..with a good clutch you dont have to let out the pedal as far...
Old Apr 14, 2006 | 10:30 PM
dazzellers_95's Avatar
dazzellers_95
yup, and if your in need of a new clutch, look for an 03 pt cruiser clutch assembly used about 75 bucks and alot better instead of stock neon. just got mine in, and ready to install.
Old Apr 15, 2006 | 03:45 AM
casper's Avatar
casper
ORIGINAL: dazzellers_95
Why would you buy a used clutch? Thats like putting used brake pads on your car!!!!!!!!!!
