another wiring problem: dead battery
Old Apr 13, 2006 | 01:34 AM
spudsterier's Avatar
spudsterier
Default another wiring problem: dead battery
my battery has been dying alot lately..i can charge it and then a couple hours later it will be dead again without starting or driving it.....when you disconnect the battery the positive clamp sparks, but it shouldnt....however the sparking is reduced when you remove the fuel pump fuse..but weather the fuel pump fuse is in or not, the only way to completely stop the sparking is to remove the interior lights fuse....i just was wondering if anyone had any ideas before i rip the car apart again, since i cant drive it until i fix the battery problem(and i really wana drive it again since its been too long)
Old Apr 13, 2006 | 12:32 PM
highline95jl's Avatar
highline95jl
Default RE: another wiring problem: dead battery
Sounds like your power cable is grounding out somewhere bro.
