AFTERMARKET RADIO
Old Apr 13, 2006 | 06:56 PM
#1NEON's Avatar
#1NEON
Default AFTERMARKET RADIO
HI GUYS I AM A OWNER OF A 96 NEON. ONE OF MY FIRST MODDIFIACTION TO THE CAR IS A NEW RADIO BUT I CAN SEEM TO GET IT TO WORK.I TOOK THE COVER OF THE DASH TO GET TO THE OLD RADIO AND TOOK OUT THE 2 SCREWS THAT HOLD THE RADIO IN PLACE. AFTER I TOOK THE OLD RADIO OUT I UNPLUGED THE TWO PLUGS ,THE GROUND AND ANTENNA.THEN I DECIDED TO CUT THE PLUGS OF THE 2 CABLE SETS TO STRIP THE CABLES AND HOOK THEM TO THE NEW RADIO WIRE HARNESSES. BUT THIS IS WERE I GET STUCK BECAUSE I DONT KNOW WHICH CALBES HOOK UP TO WHICH .ONE OF THE HARNESSES THAT CAME WITH THE OLD RADIO HAS A YELLOW RED AND BLACK THICK CABLES.TO WHICK CABLES DO THESE HOOK UP TO. AND WHICK CABLES ARE FOR THE SPEAKERS.PLEASE HELP
THANK YOU
Old Apr 13, 2006 | 07:14 PM
casper's Avatar
casper
Default RE: AFTERMARKET RADIO
My best suggestion is to reconnect the plugs that you cut and go buy a $10 wiring adapter that will plug right into the stock plugs and has a wiring diagram with it. Either that or go buy a haynes manual with the wiring schematic for $15.
