Help Help Help!
Old Apr 16, 2006 | 05:33 PM
97blueneon's Avatar
97blueneon
Default Help Help Help!
OK... I have a 97 Dodge Neon.. and i havent had not 1 problem to this day got 150K on this car. brakes spark plugs normal ****. then the other day I was hooking up my stereo and i had to reroute a power wire from my battery to the stereo. all is good and well.then I wired up some led hood sprayers for windshield. thru switches. I obviously must of wired it backwards because afta i was done i went to start the car.it turned over numerous times but didnt start.then i stopped for about 10 min.went to turn it over again and it wouldnt even do that.just dead. I work at canadian tire so I got my battery checked all good charged right up.. put it back in still wouldnt turn over. so I talked to the mechanics and one of them said check the main fuses in the engine compartment and in the car next to the steering wheel.I do not see any blown fuses. and I really dont want to spend 50sum bucks on a charging system test.so I was wondering if anyone on here would have any possible solutions to this......
Thankyou for everything,
S.M
Old Apr 16, 2006 | 06:05 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: Help Help Help!
Best thing I can suggest, is to unhook your LED washer sprayers and hook the wiring back up to the way it was before you did the LED's. Then try and start the car. It may sound like a pain, but you should always backtrack to a last known working configuration if possible. Since its just a matter of unhooking a couple wires....maybe try that first?
Old Apr 17, 2006 | 12:56 AM
HabitatHxC's Avatar
HabitatHxC
also this may sound dumb but it happend to me. After replacing the head gasket we went to start it up and it wouldn start, then we took the batery cable off and put it back on ALL THE WAY DOWN and she fired right up... it wasnt on the terminal all the way and she wouldnt run thats just what happend to me!
Old Apr 17, 2006 | 03:13 PM
casper's Avatar
casper
If it was working before you screwed with it and now it isn't you screwed up. Retrace your steps and you will find the problem.
