mopar ecu
Old Apr 20, 2006 | 12:03 AM
ScrapYurImport's Avatar
ScrapYurImport
Default mopar ecu
Hey i was wondering about the mopar perfomance ecu.
Is it necissary to run premium gas.
Also is it worth the money.
What are the hp gains?
thanks guys!!!!!!!
Old Apr 20, 2006 | 12:11 AM
casper's Avatar
casper
Default RE: mopar ecu
You don't have to run premium, but you really should. As for HP increase, that all depends on what else you have on the car. You should see about 10 hp on a stock motor.
Old Apr 23, 2006 | 03:44 PM
RadarLove's Avatar
RadarLove
If you don't run premium, you risk damaging the engine. The timing is much more advanced, and the PCM will not be able to retard timing enough on lower octane fuel if you start knocking (bad tank of gas). The PCM will be retarding near its limit just from you running regular unleaded fuel in there.
The PCM only takes a couple of minutes to swap out, you can do it in less time than it takes to fill up the car. That way you could keep the stocker in there for everyday driving, and the Mopar unit for a day at the track.
Best of luck!
Old Apr 23, 2006 | 07:24 PM
spudsterier's Avatar
spudsterier
sounds like now would be a bad time to get a performance pcm if you dont wanna switch it out once and a while...due to gas prices......2.99 for premium out here(today, but who knows about tomorrow)
Old Apr 24, 2006 | 01:58 AM
casper's Avatar
casper
ORIGINAL: spudsterier
LOL, its $2.99 for regular here.
Old Apr 24, 2006 | 09:09 AM
spudsterier
just saw it for 3.19 regular this mornin
Old Apr 26, 2006 | 08:14 AM
RadarLove's Avatar
RadarLove
I used to fill up every day. Now I fill up every 6-8 weeks... Haven't checked gas prices lately
