PCV location on 97 neon?
Old Apr 20, 2006 | 03:06 AM
97blueneon's Avatar
97blueneon
Default PCV location on 97 neon?
Wanted to change the pcv valve and I was just wondering where it was located.i looked around and didnt see anything?
Old Apr 20, 2006 | 07:17 PM
spudsterier's Avatar
spudsterier
Default RE: PCV location on 97 neon?
the pcv valve is right on top of the valve cover, should be on the passenger side...has a black hose going from the valve cover to the throttle body
Old Apr 21, 2006 | 08:33 PM
3.0van97's Avatar
3.0van97
The PCV is between the "runners" (whatever you call them) of the intake. Just look at the intake and you should see a hose. PCV's at the end of it.
Old Apr 21, 2006 | 09:04 PM
5.0LTREATER's Avatar
5.0LTREATER
you both are correct. It depends on whether you have a dohc or a sohc as to who gets the gold star. If it is a sohc 3.0 wins, a dohc spud wins.
