Exhaust pipe
Hey guys I have a bad exhaust pipe on my 95 sohc that needs replaced (sounds HORRID) and i finally have the money to buy one but is there any one that is better than another or do i just need a stock one to replace it? the exhaust system is my first performance mod i am making and wanted to spend the money in the right place thanks for your advice and suggestions
if you want it to sound really mean you can get a borla exhaust system or have a exhaust shop do something similar for hundreds cheaper
i have my catalytic converter cut out and i have a resononator in the middle of the whole exhaust system and it sounds mean.
I took the stock exhaust off my SRT and put it on my 98 sohc. I found a cast header manifold off a 2nd gen magnum motor and put it on my 98. (The magnum manifold has a big square flange where the cat bolts up, the non magnum manifolds have the usual two bolt ball socket style). Anyway, the magnum stock header manifold will bolt right up to the converter off of the SRT. The exhaust is a stock fit with the exception of where it goes over the rear suspension, and the hangers in the back. I had a local exhaust shop "customize" it for 35 bucks. They didn't have to use any of thier own material.
Not flaming you habitat, but the way you have yours run, you do not get equal flow to both sides. There is too much of a dramatic cross to the right hand (passenger side) tip. This is why the drivers side tip is black and the passengers side is nice and shiny in your pic.
You can pick up a stock SRT exhaust on ebay from 35 to 75 dollars plus shipping. The magnum manifold will run you about 30 dollars in a junk yard. Just a tip, if it is an 01 magnum, and you can, get the cam and valve springs. Nice low dollar hp gain. Below is a picture of the back end of the stock srt exhaust. This exhaust system is listed on ebay right now.
it flows really well out of both, and thers a butterfly in the T where the right tube connects to the left so that it flows a little better, as far as it being darker and less shiny its due to the camera lighting, there both really shiny when i look at them and the very tips of both are blackend
im in the prosses of making a fat dual exhaust two manga 4' race mufflers as showin in the picture shounds me as heck when i step on it.[IMG][/image
well i only have one on it now but after i get my hann racing turbo kit ill get my exhaust finished up.
