Suspension!
Old Apr 25, 2006 | 12:16 PM
Niki_lauda's Avatar
Niki_lauda
Default Suspension!
hi all! i wonder what differences are in 1st and 2nd generation neon suspensions?? how i know there ara so which is better and why? if u have some photos please post it ok??
Old Apr 25, 2006 | 06:52 PM
casper's Avatar
casper
Default RE: Suspension!
Neither stock suspension is any good. You are gonna want a stiffer, lower aftermarket suspension if you are serious about the car.
Old Apr 26, 2006 | 08:39 AM
RadarLove's Avatar
RadarLove
The 1st gen springs are about 1.5" shorter at ride height. The strut travel is matched to the springs. 1st gens have a little under 3" of travel, 2nd gens a little under 4". The clevis brackets are 1/4" wider or so on the 2nd gens. The spring rates are the same (except ACR fronts for both gens). The Base/ES and R/T struts were valved a little stiffer than the Highline/SXT/SE. The rates didn't change much between generations.
For a stock setup, I'd take the 1st gen ACR setup. But barely... A 2nd gen ACR setup with 1st gen springs would be better. But if I went with a 2nd gen setup, I'd have to own a 2nd gen, and I ain't gonna...
Best of luck!
Old Apr 26, 2006 | 11:46 AM
das2123's Avatar
das2123
ORIGINAL: RadarLove
Best of luck!
