tranny swap
Old Apr 29, 2006 | 03:47 AM
HabitatHxC's Avatar
HabitatHxC
Default tranny swap
Ok so ive decided to do a tranny swap from atx to mtx, is there anywhere that i can find a step by step or a good guideline? what kind of things do i need to know? eveeryones telling me it will bolt right up and it can be done in a 2 days or less, i just need a second oppinion.
Old Apr 29, 2006 | 10:04 AM
spudsterier's Avatar
spudsterier
Default RE: tranny swap
it will just bolt up, and the main thing that takes time is the pedals........i could walk you through it all but thats alot of writing....if you dont find the info sumwhere, let me know and i will do it then....im just really tired and getting redy for bed
Old Apr 29, 2006 | 11:35 AM
das2123's Avatar
das2123
CLICK ME for a great how-to with pics!
Old Apr 30, 2006 | 05:22 AM
HabitatHxC's Avatar
HabitatHxC
Thanks! i dont know about it though, i thought i found a person to do it, and someone told me not to trust him with it, so i dunno, i dont have the experience to do it myself, mabye with the help of some reliable friends! but any who i still dunno (especially after lookin at the price they had(
Old Apr 30, 2006 | 10:39 AM
spudsterier
if you do it, it wont cost as much as that page said....could just go buy a wrecked manual neon from a junk yard for a couple hundred bucks and there you go
Old Apr 30, 2006 | 02:19 PM
HabitatHxC's Avatar
HabitatHxC
do you think they would charge me more than 250? im cheap (due to motor work and my job)
Old Apr 30, 2006 | 09:01 PM
casper's Avatar
casper
Probally more like $500 for someone to do the swap. Its really not all that hard if you have basic mechanical knowledge and a set of tools. Pick up a Haynes manual and follow the directions for ATX removal MTX installation. And I believe there is a section on the pedals too, they are not hard just a PITA.
Old May 1, 2006 | 08:00 PM
burpleneon's Avatar
burpleneon
get the shifter cables and the pedle bracket and the bobble strut mount "thats a must have" and the passenger side cv joint. i just did a swap, you can do it in a weekend and get the whole clutch cable with the little bushing that goes in the fire wall . if you use the stock comp the speedmeter wired will be the same their color match so thats not a prob but get the plug that matches the tranny the nuetral safty switch is a wire twist and tape thing. if you need to know the wire set up tell me and ill tell you
Old May 5, 2006 | 05:58 PM
93 tona's Avatar
93 tona
Yeah, iwant t do this to, but i want someone to help me who what to do. also, I was told that a turbo charged atx is better than a torbocharged mtx.
also if you do it dont switch the tb the atx is bigger by like 2mm i think. it flows better.
Old May 5, 2006 | 07:03 PM
das2123's Avatar
das2123
ORIGINAL: 93 tona
That's ridiculous. A turbo ATX neon is harder as a daily driver.
ORIGINAL: 93 tona
ATX TB is 52mm and MTX TB is 49mm.
