Idle down issue, need help!!
Old May 4, 2006 | 08:41 PM
CenCalNeon98's Avatar
CenCalNeon98
Default Idle down issue, need help!!
I have a 98 sohc atx and my problem is with my car idleing down. Whenever I start my car I'll let it idle for a cpl seconds and than step on the gas a little, it used to idle back down just fine but now it'll idle down a little bit,stay there for a cpl seconds and than idle down all the way, this is'nt normal for my car. Now me and my family went on a trip to San Diego last weekend (a cpl hundred miles south from us) and the car was fine and I noticed this issue right when we got home. What can be the problem? I have a 3.0 cai which I cleaned the filter, MPX UDP and a Pacesetter header which one of the flange bolts has snapped off so I've tightened the remaining bolt until I get a new header next month, I don't if any of these mods have anything to do with it.
I've also done the oil and tranny fluid and gasket last month just for this trip.
Old May 5, 2006 | 02:36 AM
das2123's Avatar
das2123
Default RE: Idle down issue, need help!!
Things that come to my mind are spark plugs, IAC, and TPS and possibly PCV valve. Hope this helps!
