Newbie with cooling fan question
Old May 5, 2006 | 03:16 AM
mnmattie's Avatar
mnmattie
Default Newbie with cooling fan question
Hey guys,
New to the Neon crowd! First question:
I just picked up the car today and I drove it home and I pulled in the driveway and noticed steam from under the hood. Opened the hood, let everything cool down and came back to realize that my cooling fans aren't connected. Now the trick is that the OEM connector has been cut off and I have no idea to tell which connector hooks up to the fans. Oh and it's a 95 SOHC 5-speed before I forget. I'm heading to the yard on saturday and wanted to see if anyone had some ideas/pointers for me to look for before heading to get parts. thanks!
-Mattie
Old May 5, 2006 | 10:52 AM
RadarLove's Avatar
RadarLove
Default RE: Newbie with cooling fan question
Did they actually cut off the connector? or is it just disconnected and dangling down somewhere?
Take a good look at the connector on the fans themselves, I don't remember if that was one of the connectors that changed over the years. You might want to try running straight power to the fans and make sure they work before heading to the yard... You might also swap the fan relay for the horn relay to make sure it works (black box behind the battery), and check the fuse...
Best of luck!
Old May 5, 2006 | 10:56 AM
mnmattie's Avatar
mnmattie
the connector is definetely cut. What I want to know is what connector on the harness is suppose to go to the fan. thanks
Old May 6, 2006 | 01:29 AM
mnmattie's Avatar
mnmattie
hey guys, i found where the wire was cut and I was able to fix the problem. thanks!
Old May 6, 2006 | 01:34 AM
das2123's Avatar
das2123
ORIGINAL: mnmattie
What help? Didn't look like anyone really helped...but glad to hear you got it fixed.
Old May 6, 2006 | 03:45 AM
mnmattie's Avatar
mnmattie
well I wasn't going to flame anyone for not helping, that would be pointless.
