New Tires
Old May 5, 2006 | 05:06 PM
RayDog26's Avatar
RayDog26
Default New Tires
a while back i bought new rims and kept the stock tires because they were still good... now i plan to get new tires.. i have 185/65/14 i plan to get hankook 195/65/14 $48 a tire.. will they fit without a problem. so far i been told yeah but i thought i would check here too.
Old May 5, 2006 | 05:27 PM
das2123's Avatar
das2123
Default RE: New Tires
Yes they will fit...I have 195/60/14 Falken's on my neon.
Old May 5, 2006 | 08:55 PM
5.0LTREATER's Avatar
5.0LTREATER
Just a note (kind of a loose rule of thuimb): To keep the speedo as close as possible, for every 10MM you gain on the first number, drop five on the second number.
i.e. 185/65/14 = 195/60/14. 205/50/17 = 215/45/17. You get the picture. This will give you as close as possible to the same diameter, but you will gain about 1/2" more width. Good trade in my book. You will be fine if you use the 195/60/14. If you use the 195/65/14, you will be going faster than the speedo says by about 1.42 mph at 65 mph. This error increases as you speed increases. Hope it helps.
Old May 5, 2006 | 09:08 PM
5.0LTREATER
Also as an afterthought, if you know anyone running stock SRT wheels with the 205/50/17's on them, here is a tip. There are only three or four main line manufacturers of the 205/50/17 and they are really expensive, from 129.00 to 209.00 each. By going up to the 215/45/17 you gain 2/3" in width and save any where from 55.00 to 140.00 dollars a tire. I am running the Riken Raptors on mine and I pay 64.00 each for them. Riken is also made by Michelin. Can anyone say "replacement for the Pilot Sport"? I know this seems it is on the wrong forum, but Riken has about 35-40 different performance sizes. So I figured this would be good info for everyone.
Old May 5, 2006 | 11:54 PM
das2123's Avatar
das2123
^^^Why not run 205/40/17's and stay extremely close to the speedo?
Old May 6, 2006 | 02:48 AM
HabitatHxC's Avatar
HabitatHxC
i have 205/40/17 and the little radars they put on the side of the road is usally 1 off either way.
Old May 6, 2006 | 01:58 PM
RayDog26's Avatar
RayDog26
im only sticking with 14's cuz i just bought the rims in that size. i wasn't planning to keep this car so i figured i would keep stock size, just get some thing that looks better. plus i didn't want to spend money on new tires at the time too.
so 195/65/14 will throw off my speedo... and come to think of it i went and looked at my tires and they says 185/75/14 which isn't the stock size so i dunno whats up with those... definitely need some new ones tho.
Old May 7, 2006 | 05:25 AM
das2123's Avatar
das2123
ORIGINAL: RayDog26
Yes, by 1.42 mph. If your speedo says 65, then you will be actually going 66.42 mph. Not much difference, but thought you should know.
Old May 7, 2006 | 05:55 AM
RayDog26's Avatar
RayDog26
yes thats good to know.. according to discount tire direct tho it won't....so im a little confused..
Old May 9, 2006 | 02:40 PM
5.0LTREATER
The list below shows most of the Stock Neon tire sizes.
2002
4-dr Base P185/65 R14
4-dr SE/ES P185/60 R15
4-dr ACR P185/60 HR15
4-dr R/T P195/60 VR16
2001
4-dr Neon P185/65 R14
4-dr Neon (option) P185/60 R15
4-dr ES/LX P185/60 R15
4-dr R/T & Sport P195/50 VR16
2000
4-dr Neon ES/LX P185/60 R15
1998-99
2/4-dr Neon/Sport/Expresso/Style P185/65 R14
4-dr ACR P175/65 HR14
2-dr ACR P185/65 HR14
2/4-dr R/T P185/65 HR14
1996-97
2/4-dr Base P175/70 R14
2/4-dr Highline/Sport/Expresso P185/65 R14
2-dr ACR P185/60 HR14
1995
4-dr Base P165/80 R13
2/4-dr Highline P185/70 R13
2/4-dr Highline (option)P185/65 R14
2/4-dr Sport P185/65 R14
