12 crane cam ????'s
Old May 7, 2006 | 06:30 PM
dazzellers_95's Avatar
dazzellers_95
Default 12 crane cam ????'s
the #12 crane cam installed on a ported and polished head. my question is this...
does it need new springs and retainers or is it ok for a little while to run with stock ones???
this is for a 95 sohc btw.
Old May 8, 2006 | 05:28 PM
casper's Avatar
casper
Default RE: 12 crane cam ????'s
You should be fine with the stock stuff. The #12 grind is not that radicle
Old May 8, 2006 | 09:14 PM
dazzellers_95
ORIGINAL: casper
cool, thanks casper. i really was not sure, but i was willing to take the chance. head will be done tomorrow and i should be into the 14's!
Old May 11, 2006 | 05:19 AM
lblackneon's Avatar
lblackneon
I'd get the valve springs and if u want to be extra extra safe get the titanium retainers too. With the 12 the retainers aren't necessary.
Old May 15, 2006 | 08:44 AM
RadarLove's Avatar
RadarLove
The only cam that doesn't recommend/require upgraded springs is the Zex/Comp Cams 200 grind. Mopar even recommends upgraded springs for the 4HP cam, which is the stock '95 cam... Not surprising, since my valves start floating not much higher than 7200 rpm ('95 SOHC). Titanium retainers are never required. When Jeff B was still SOHC and running the Crane #004 (think bigger than the 0014, and there is a 005...) at 8000 rpm, it was with stock retainers.
Stock Magnum springs have shown to be more reliable than the Cranes. Cheaper too.
Best of luck!
Old May 24, 2006 | 06:42 PM
dazzellers_95
all done, waiting til friday for the track...
dont mind the mess behind, i own a junk yard, lol.
[IMG]local://upfiles/25678/0FDAC1CA596C4176AB91B9D9A8EB285E.jpg[/IMG]
