catalitic converter
Old May 9, 2006 | 12:17 AM
detroitdieselman's Avatar
detroitdieselman
Default catalitic converter
Does anyone make a pipe to replace the converter?
Doug
Old May 9, 2006 | 01:18 AM
das2123's Avatar
das2123
Default RE: catalitic converter
ORIGINAL: detroitdieselman
A longtube header will replace the cat
Old May 9, 2006 | 02:14 AM
neon2_0t's Avatar
neon2_0t
You could easily fab one up.
Old May 9, 2006 | 02:21 AM
FuzzRacer's Avatar
FuzzRacer
Either a long tube header ( check out howellautomotive) or a test pipe with or without resonator would do just fine or just fab one up like neon2 said
Old May 9, 2006 | 02:58 AM
neon2_0t's Avatar
neon2_0t
Flange:$5
2.25 exhaust pipe: $15
Then Weld away!
Old May 9, 2006 | 10:56 PM
detroitdieselman
What about the O2 sensor? Isn`t it in the cat as it sits right now? And if I root out the cat, or eliminate it all together, what will the O2 sensor react like?
Yeah, fabing something would be easy.
Old May 10, 2006 | 03:04 AM
FuzzRacer's Avatar
FuzzRacer
you don't really need your downstream O2 sensor( unless you live in a state where emissions are checked), all that one does is check how the cat is doing and it isn't inside your cat it's just before it. your front one( located on the header) is the one you really need. removing your downstream O2 will cause your cell to through a 21 which basically means one of your O2 sensors are bad. if your worried about passing your states emissions and don't want the cel to through a code then you can by the a downstream eliminator which tricks the pcm to think that there is one actually there, it also will stop the cel from coming on( due to the missing O2 sensor) howellautomotive sells them hope some of that was helpfull good luck !!
Old May 10, 2006 | 09:35 AM
detroitdieselman
I read some comments on here where it really don`t do any good to remove the cat. Am I wasting my time? Thanks for all the previous replys
Old May 10, 2006 | 10:36 AM
spudsterier's Avatar
spudsterier
i took mine out, the only thing that you really notice is how much louder it is....i welded a piece of pipe in place of the cat...then bought an o2 fitting from ebay...drilled a hole in the pipe and welded the fitting on there..that way the sensor is still there...you can find them in jegs under o2 sensor bung........but removing the cat doesnt make a whole bunch of difference
Old May 10, 2006 | 12:23 PM
das2123's Avatar
das2123
Removing the cat doesn't help performance wise. Only hurts the car's emissions. It flows well from the factory and you could always replace it with a high flow cat.
