TB spacer
Old May 11, 2006 | 12:23 PM
jdog08's Avatar
jdog08
Default TB spacer
does a throttle body spacer give you any kind of horsepower gains
Old May 11, 2006 | 03:59 PM
das2123's Avatar
das2123
Default RE: TB spacer
ORIGINAL: jdog08
NO! It moves the TB up off the manifold allowing extra volume for air flow to achieve more laminar flow.
Old May 11, 2006 | 05:53 PM
HabitatHxC's Avatar
HabitatHxC
Soooo a better sound then?
Old May 11, 2006 | 05:59 PM
das2123's Avatar
das2123
ORIGINAL: HabitatHxC
Possibly...
Old May 15, 2006 | 08:47 AM
RadarLove's Avatar
RadarLove
The idea is to have less turbulence by allowing the air to straighten out some. Cool idea for a carb, not so effective on a TB on a plenum-style intake manifold. It will increase plenum volume, which is a good thing. If you have a DOHC, you can get a manifold spacer as well. Vitor sells both, and dynoed the combo for ~5 HP. He does admit that it's probably all from the bigger plenum, and the resulting a/f changes because of that (PCM assumes a certain volume).
Best of luck!
