gauges
Old May 13, 2006 | 06:53 PM
jdog08's Avatar
jdog08
Default gauges
i just got a set of hiper reverse glow gauges to replace my old ones and i got them in just fine but i couldnt figure out how to hook the electrical part so that they would glow so if anybodys anything please help
Old May 13, 2006 | 06:59 PM
Bassboy's Avatar
Bassboy
Default RE: gauges
They didnt come with instructions? I am guessing it has a positive and ground, ground it out anywhere close that you are able to and the positive I am assuming you would hook to the dimmer switch or tie into the wire going to the stock gauges to dim them. hope this helps some.
Old May 13, 2006 | 07:06 PM
das2123's Avatar
das2123
Default RE: gauges
I forgot the colors of the wires, but you have to tap into the interior light switch. The one for the dome light and dimmer. I think one of them is yellow & black.
Old May 13, 2006 | 07:09 PM
jdog08's Avatar
jdog08
Default RE: gauges
well the gauge cluster connects with to big plugs there is no wires
Old May 13, 2006 | 10:27 PM
das2123's Avatar
das2123
Default RE: gauges
ORIGINAL: jdog08
You gotta go under the dash, by the pedals and look for the wires. Not in the cluster!
Old May 14, 2006 | 01:29 AM
jdog08's Avatar
jdog08
Default RE: gauges
so does anyone know what wires exactly and where they are located exactly
Old May 14, 2006 | 02:02 AM
Bassboy's Avatar
Bassboy
Default RE: gauges
It should be right up under the dash on the left side, like das said its a yellow and black wire (use a test light to confirm this) its a wire that comes from the switch on your headlight switch... check which wire comes on when parking lights and headlights are both on and dims when you turn it down. I'm not too familiar with the wiring in a neon yet, have only installed a stereo system in mine so far.. I know that its not too hard to do tho, its the same wire I used for the tach in my Shadow.
Old May 14, 2006 | 11:52 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: gauges
if you want to give in and buy a hayes manual for your car, it will have all the wiring diagrams in there so you know what is what. and nope, i have no idea what color the dimmer wire is in all that mess. (a circuit tester may also be a good in this situation to figure out wiring)
Old May 14, 2006 | 10:38 PM
jdog08's Avatar
jdog08
Default RE: gauges
hey everyone i got them hooked up and they look awesome. Thanks for the help and das you were right the wire is yellow and black
Old May 15, 2006 | 12:14 AM
das2123's Avatar
das2123
Default RE: gauges
Good to hear and glad I could help.
