What should I buy for a new fuel pump and filter
I'd go with the Walboro, only cause it's cheaper than the ones at Autozone or O'reilly's.
*edit* In case you didn't know, if you get the Walboro, you will replace just the pump and use your original canister.
There's no filter to replace on your '97. Well, technically... the "fuel filter" is part of the regulator assembly and should last the life of the car, adn then some. And there should be some sort of filter sock on the pump assembly, although I might be thinking of a different pump from another recent job...
Best of luck!
Best of luck!
