update
Old May 20, 2006 | 11:19 AM
mnmattie's Avatar
mnmattie
Default update
put new plugs and wires and an o2 sensor in the car, tried to start it...no start. ran the codes.....it gave me no signal from the TPS and less than 5V to the MAP sensor. Is there something that would throw both of these codes? I was going to swap the TPS from my old car over and see if that'll at least clear the one code. What do you guys think?
-Mattie
Old May 21, 2006 | 01:24 AM
ewetho's Avatar
ewetho
Default RE: update
Pull the 02 and see if it clears. Should make no difference. If no other changes took effect rom a running car then have to look here you worked first. Look around make sure you did not pinch a wire or knock a connecto loose.
Old May 22, 2006 | 01:06 AM
mnmattie's Avatar
mnmattie
Default RE: update
I should have stated that I just purchased the car and it didn't run before. I have a TPS coming tomorrow, I'll throw that on and go from there
