neon engine swap
Old Jun 25, 2006 | 06:27 PM
das2123's Avatar
das2123
Default RE: neon engine swap
ORIGINAL: rrwertz
Don't bother swapping in a 2.0 dohc.
best swap if your car is sohc is a magnum swap.
You think the Magnum has more potential than the DOHC? It doesn't have the aftermarket support that the DOHC has right now.
Old Jul 7, 2006 | 12:51 AM
got magnum's Avatar
got magnum
the magnum head is the strongest head that the neon has doing a mag swap in to a 95, p&p, and all the good stuff, hope to get low 13s, doing the dry ice trick this weekend for the weight.
Old Jul 7, 2006 | 01:24 AM
das2123's Avatar
das2123
ORIGINAL: got magnum
Stronger that the DOHC? Where's your proof?
Old Jul 7, 2006 | 04:28 AM
99SRT4's Avatar
99SRT4
DOHC IS THE WAY TO GO. I had SOHC .a 2.4 stratus motor .a 2.0 dohc and now a SRT4 MOTOR SWAP.......GO WITH A DOHC[sm=nxsmile.gif]
Old Jul 8, 2006 | 08:05 PM
Kartoon's Avatar
Kartoon
I have a 1997 dodge neon with a 2.0 SOHC that is missing on two cylinders so I decided to swap the engine with a 2.4 stratus/caravan engine but one problem I dont know how. INFO ON HOW TO DO IT ANYBODY PLZ!!! Also what year model stratus/caravan should I use?[:@]
Old Jul 8, 2006 | 09:36 PM
das2123's Avatar
das2123
^^^A simple search and you would have found that I have posted this link many times...
http://neon-owners.org/neon/tech/how...onversion.html
Old Jul 14, 2006 | 09:12 PM
DNeon's Avatar
DNeon
Does the DOHC an SOHC use the same block?
Old Jul 14, 2006 | 09:23 PM
das2123's Avatar
das2123
ORIGINAL: DNeon
Yes!
Old Jul 15, 2006 | 02:40 AM
FuzzRacer's Avatar
FuzzRacer
I don't think we are gona see any proof any time soon about that mag head lol, I found that amusing, Hm dohc or.... sohc now I wonder which is gona put out more power? 1 cam or 2 cams ? lol I have that info you gave about swaping saved on my comp das, been thinking about a swap my self got some info saved from radar as well
Old Jun 7, 2012 | 12:04 AM
tobie@vistabeam.com's Avatar
tobie@vistabeam.com
what years will the head swap out with my 2001 base model non egr I want to stick with the single ]overhead cam I bought the car cheap and I want to keep it that way. bought with a broken timing belt. I just want to drive it and enjoy it.
