Battery Relocation for CAI
Old Jun 3, 2006 | 10:13 PM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Default Battery Relocation for CAI
Has anybody ever relocated their battery to the trunk so they could place a Cold Air Intake in the place of the battery. Or is this a dumb idea? I think that it might work if the battery could be relocated. The cold air intake wouldn't be much of a problem I don't think. It was just an idea. Tell me what you guys think.
Old Jun 4, 2006 | 12:39 AM
spudsterier's Avatar
spudsterier
Default RE: Battery Relocation for CAI
i have been wanting to do that for a while. and i was just goin to run 0 gauge power wire from the battery to the engine compartment. but i have been trying to decide how i am going to hook the power wire to the wiring harness without it lookin too chetto
Old Jun 4, 2006 | 01:33 AM
IGottaFreeNeon
Dude, we drive Neons, we're all about ghetto. I think you should do it and then if it looks good, I'll do it too. If it looks like garbage I'll tell you that you shouldn't have done that. Sound good?
Old Jun 4, 2006 | 10:25 AM
spudsterier
maybe i will do it within the next few days...its a project car so if it doesnt work good enough, then no big deal it can go back to normal...i will get some pics and post them when i do
Old Jun 4, 2006 | 03:15 PM
ewetho's Avatar
ewetho
Just get proper wire splices like from a stereo shop and then it should look good as you add your lengths.
Old Jun 4, 2006 | 04:23 PM
FuzzRacer's Avatar
FuzzRacer
Relocating the battery isn't a bad Idea at all, Modernperformance sells a intake that is designed with that concept in mind,its called the kirk CAI but you can buy the supplies yourself and save a lot of money that way. they also sell kits to do it but your it's probably cheaper to go wireing route and its just more fun that way. where you relocate it( Im guessing the trunk) don't forget to make sure that bad boy is secure and not floping around good luck
Old Jun 4, 2006 | 11:10 PM
spudsterier
ok i changed my mind on the relocation....im not gonna do it..im just gonna part out the car and junk the rest
Old Jun 24, 2006 | 08:25 PM
IGottaFreeNeon
ok, now instead of relocating the battery, I think I'm just gonna go with neonricks idea. Use a smaller battery, cut the battery tray back and make my own intake out of muffler tubing. I just need to know what battery is small enough to use but not gonna hurt my car or its capability to start.
Old Jun 24, 2006 | 10:26 PM
das2123's Avatar
das2123
ORIGINAL: IGottaFreeNeon
I know people up north use tractor batteries with no startimg problems. $20 at Wal-mart!
Old Jul 16, 2006 | 11:06 AM
neon.ace's Avatar
neon.ace
Max Current you are drawing from a stock neon is 40 amps.(That is the largest fuse in the car) You could probobly run 2-4 ga. wire and be fine. Run your wire under your carpeting, through the firewall and BAM! No ghetto (not really). Just a thought. Peace and quail grease.
