1995 Neon Speedometer, gas Guage, etc.
Old Jun 5, 2006 | 02:43 PM
DCWebb's Avatar
DCWebb
Default 1995 Neon Speedometer, gas Guage, etc.
Speeedometer, odometer, gas guage, ignition-on buzzer all quit at the same time, resumed briefly then quit permantly. My repair guy says I need a new insrument cluster??? Can I relace this myself? Thanks for all help with my little green money-pit!
Old Jun 5, 2006 | 02:46 PM
das2123's Avatar
das2123
Default RE: 1995 Neon Speedometer, gas Guage, etc.
You can try to reflow the cluster first, but yes you can replace it yourself. It's easy...Click the link for help...
https://dodgeforum.com/m_179505/tm.htm
Old Jun 5, 2006 | 02:56 PM
spudsterier's Avatar
spudsterier
if its a 95, just on a hunch try turning the key back a little when the car is running....who knows???
Old Jun 17, 2006 | 11:56 PM
95SOHC's Avatar
95SOHC
to be honest..for what it cost to get a new instrument..i wouldn't even bother trying all this different ****..i had that problem with mine before and it's so easy to change...it cost me $35 for the instrument and like 10minutes to install...pry your dash outta place..remove it...get a phillips screwdriver unscrew the 4 screws holding the instrument and pull it out..and that's it..ur done!!
Old Jun 18, 2006 | 12:35 AM
das2123's Avatar
das2123
^^^That's all true, but some people don't wanna spend the $35 when all you need to do is reflow the cluster. Takes about 5-10 minutes longer than swapping clusters and costs nothing
Old Jun 18, 2006 | 05:42 AM
pimpberetta's Avatar
pimpberetta
ORIGINAL: spudsterier
Funny you mention that spud, becuase I have to do that exact thing everytime I start my car.. Not cool to say the least[:'(]
Sean
