99 Neon question
Old Jun 5, 2006 | 06:55 PM
gtxpooch's Avatar
gtxpooch
Default 99 Neon question
If i back my neon out into the street and park it, when I start it later to move it or go somewhere it chugs and CEL comes on but no codes. Any ideas? Thanks in advance
Old Jun 5, 2006 | 08:13 PM
das2123's Avatar
das2123
Default RE: 99 Neon question
Does the CEL stay on?
Old Jun 6, 2006 | 01:36 AM
gtxpooch's Avatar
gtxpooch
CEL stays on but runs okay.
Old Jun 6, 2006 | 01:49 AM
ewetho's Avatar
ewetho
Get a code reader say at the ZOO (Autozone) and see what codes you got. There are a lot of OBDII codes do not have a direct translation to the dash OBDI style codes.
Old Jun 6, 2006 | 12:18 PM
das2123's Avatar
das2123
ORIGINAL: gtxpooch
Read the codes by turning your key to the ACC on-off-on-off-on within five seconds and count the flashes. flash-flash-flash-flash...paause...flash-flash-flash..is a code 43 for example.
Here is some more info...
http://www.allpar.com/fix/80s-codes.html
Old Jun 6, 2006 | 04:39 PM
tomthedog's Avatar
tomthedog
this happens ONLY when you back your car?
Old Jun 7, 2006 | 12:03 AM
gtxpooch's Avatar
gtxpooch
It happens when I start the car and back it out and park in the street. I the car runs for maybe a minute or so. It's done it 2 times and doesn't store codes. When I start it again it runs rough but eventually smoothes out. it does have 118K on it.
Old Jun 7, 2006 | 02:05 AM
das2123's Avatar
das2123
When was the last time you changed the plugs?
Old Jun 9, 2006 | 01:15 AM
gtxpooch's Avatar
gtxpooch
About 8000 miles ago, could it be the plugs?
Old Jun 9, 2006 | 02:12 AM
das2123's Avatar
das2123
ORIGINAL: gtxpooch
Yes it could be. Put some stock champion plugs in there or ngk's!
