96 oil leak
Old Jun 9, 2006 | 02:01 PM
icemanwbs's Avatar
icemanwbs
Default 96 oil leak
bought in 96 new..had a recall on head gasket..........had it fixed...still leaks........was told it was because they didnt change the bolts ?......( stretched?)........anyone hear of this ?bbb
Old Jun 9, 2006 | 02:13 PM
unclemike's Avatar
unclemike
Default RE: 96 oil leak
I thought the head gasket kit came with new head bolts? Anyway the head bolts are called torque to yeild. They get torqued to a specification that actually stretches the bolt slightly to gain maxmimum clamping power. They are good for one use only. Look at this as an opportunity to install a header since the head should come off again.
Old Jun 9, 2006 | 03:29 PM
das2123's Avatar
das2123
Headgasket should have been replaced with an MLS headgasket and the bolts SHOULD NOT be reused.
