no balls
Old Jun 10, 2006 | 05:20 AM
XJ bmx XJ's Avatar
XJ bmx XJ
Default no *****
ok my girlfriends neon has NO ***** at all im not shur why im thinking maby cloged cat or maby cloged injectors it also dont wanna kick down a gear wen it should maby TPS i dunno
by the way yes im a noob
Old Jun 10, 2006 | 12:46 PM
das2123's Avatar
das2123
Default RE: no *****
ATX or MTX? Year and milage please...
tomthedog's Avatar
tomthedog
give it a tune-up, check the trans fluid, then give it a try. if that don't help, you might have to adjust the trans belts. you'll have to pull the battery and it's holder out to get to the adj nuts. take care to discon the batt temp sensor before pulling the batt tray or your batt light will stay on.
Old Jun 10, 2006 | 01:11 PM
das2123's Avatar
das2123
ORIGINAL: tomthedog
Do you mean bands?
Old Jun 10, 2006 | 04:24 PM
tomthedog's Avatar
tomthedog
yep, my bad. might think about the trans filter too.
Old Jun 10, 2006 | 05:09 PM
XJ bmx XJ's Avatar
XJ bmx XJ
its 96 highline sohc auto trans with 120 grand on it
please excuse the bad spelling and what not
Old Jun 10, 2006 | 05:30 PM
das2123's Avatar
das2123
Change spark plugs with champion copper plugs, air filter, PCV valve, and change the tranny fluid. It mat be time for a tune-up as suggested. Have the timing belt, water pump, and tensioner pulley been replaced? The neon timing belt is a 100,000 mile belt and may snap on you soon.
Old Jun 11, 2006 | 12:25 AM
XJ bmx XJ's Avatar
XJ bmx XJ
kool thanx ill try that ill keep you guys in formed
