engine code 0743
just my luck, i fix one problem to get another.... anyways i know it has something to do with the torque converter, but i suck with transmissions, so if anyone could tell me if im completely boned or what, thanks
oh (1996 dodge neon sohc, automatic)
P0743 (M) - Torque Converter Clutch Solenoid/Transmission Relay Circuits
An open or shorted condition detected in the torque converter clutch (part throttle unlock) solenoid control circuit. Shift solenoid C electrical fault - Aisin transmission.
Couldnt tell you for sure.....but probably a bad module/sensor.
