96 neon drag project
Old Jun 15, 2006 | 09:33 PM
mmench's Avatar
mmench
Default 96 neon drag project
i am currently in the process of building my old daily driver neon into a nitrous car for the track over the summer. it has a fresh motor in it now but i am expecting to build another motor over the winter for it for a serious turbo combination. as i am about to order the nitrous does anybody have any suggestions of what i could add to it. and also will my stock ecu be good enough.
Old Jun 15, 2006 | 10:03 PM
tomthedog's Avatar
tomthedog
Default RE: 96 neon drag project
flash some skin or go home, ain't got beads that i can throw that far (i'm bs'ing).
the stock PCM (Powertrain Con Mod)? NO WAY.
NO2 you will need some type of ignition retard, may work with pcm mods.
NO IDEA about turbo. use the search eng on this site. GOOD LUCK and send some pics!
Old Jun 16, 2006 | 01:49 AM
mmench's Avatar
mmench
thanks. i know all the basic crap about turbos and nitrous but i havent really worked on neons much. i mean i have but just like minor intake exhaust suspension stuff. never indepth stuff. i mainly have exp. with big blocks and stuff. anyways thanx for input. i am taking it to the track tomorroe nite wit stock motor but stripped out. owel. i send pic definetly.
Old Jun 16, 2006 | 01:58 AM
das2123's Avatar
das2123
ORIGINAL: mmench
Your stock PCM will work fine. What you add, depends on what type of setup you want to run and what type of shot. For example, if you want to run a dry 50 shot, you are good to go.
