exhaust leak temporary fix????
Old Jun 16, 2006 | 12:18 AM
spudsterier's Avatar
spudsterier
Default exhaust leak temporary fix????
ok so this isnt for my neon, its for my durango, but could be used with anything......but my question is...i have an exhaust leak on the rango that i cant reach with the welder, so what would work the best to fix it????...i was told that you can wrap it with duck tape and then when the tape melts it will fill the gap....is this one true???or is it just a redneck myth???
Old Jun 16, 2006 | 01:23 AM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Default RE: exhaust leak temporary fix????
You could go to an exhaust shop, but since you drive a Durango you prolly don't have much money due to gas prices. You may want to invest in some JB Weld. It costs about $6 so that translates to about 20 miles for you. Try to dab it in the hard to reach area with a long stick or something. I don't know, be creative, use a finger if you can. That stuff should hold long enough till you can get it fixed or Christ returns, whichever happens first. Good Luck, hope it helps.
Old Jun 16, 2006 | 02:02 AM
pimpberetta's Avatar
pimpberetta
ORIGINAL: IGottaFreeNeon
lmao
Old Jun 16, 2006 | 06:14 AM
spudsterier
funny thing is is that its kinda true...the truck has been sitting in the yard for about a month now with the gas light on...ive been itching to go drive it but it takes 75 bucks to fill it up......i think i would rather drive the car if i can get about 10 times further on the same amount of gas....i just was wondering about the fix for now, that way if i do drive it i can put 10 bucks in it and go around the block a few times
Old Jun 16, 2006 | 04:32 PM
tomthedog's Avatar
tomthedog
slice up a beer can wrap it around the pipe and hold it on with hose clamps. the can is thin enough it can work on slight bends but not tight ones. good luck.
Old Jun 16, 2006 | 09:18 PM
pimpberetta
Is the leak at a joint by chance?
Old Jun 16, 2006 | 11:02 PM
highline95jl's Avatar
highline95jl
ORIGINAL: tomthedog
You dont seriously work on cars do you?
You can go to a salvage yard and find the joint on another durango and with a little welding fix the leek.
Old Jun 16, 2006 | 11:23 PM
neon2_0t's Avatar
neon2_0t
Am I the only one here that would think to take the exhaust off and fix it????
Old Jun 17, 2006 | 12:04 AM
IGottaFreeNeon
After I read this comment
I pretty much figured he wasn't in the mood to actually fix the problem, that's why I suggested the JB Weld. As for the beer can, it will probably work but the JB Weld is easier, plus you can use it on other stuff when you feel lazy.
Old Jun 17, 2006 | 01:35 AM
spudsterier
ORIGINAL: highline95jl
[You can go to a salvage yard and find the joint on another durango and with a little welding fix the leek.
if you happen to read the post, i cant reach it with the welder, thats why it is a leak and not a fix....i removed the cat converter and the muffler and put on a 40 series flowmaster, i cant take the exhaust off to do it because i would have to remove the trans brace, the torsion bar brace, and the front drive shaft, not to mention have it up on a lift(which i dont have)...the leak is at where two pipes are joined at a clamp wont work......i tried jb weld, but i still cant exactly reah it, and what i did put on it just ran all over....its on the top of the pipe next to the frame rail....it would be almost like trying to fix a leak on the lower top side of the cat convertoer on a neon....its just kinda hard to get too
