reset the service light
Old Jun 21, 2006 | 08:08 PM
das2123's Avatar
das2123
Default RE: reset the service light
Step up to some knowledge!!!! It works on the 95-99 neons that are OBD-2 compliant. The sec gen neons actually flash the P Code as well as some trucks! I have performed this little test on my 97 & 99 neons as well as thousands of other people.
Shall I record a little video for you ?
Old Jun 21, 2006 | 08:11 PM
dodgedlr's Avatar
dodgedlr
ORIGINAL: das2123
Your right.
What do I know....
BTW? What would "code 43" indicate is your problem?
Old Jun 21, 2006 | 08:17 PM
das2123's Avatar
das2123
ORIGINAL: dodgedlr
Single or multiple cylinder misfire. The actual "P" code, what you get with a scanner, can identify which cylinder, but generally you just change spark plugs, inspect wires and the coil pack.
Old Jun 21, 2006 | 09:39 PM
dogdaysunrise's Avatar
dogdaysunrise
das is right it works on my car also. I am throwing a TC code on my 97. That is because it is a pcm from a 97 ATX car and it has an MTX.
It works on my buddies 98 intrepid too.
Old Jun 22, 2006 | 01:05 AM
FuzzRacer's Avatar
FuzzRacer
works for me just fine, that along with the Haynes manual, saves time and money.
Old Jun 22, 2006 | 01:06 AM
FuzzRacer's Avatar
FuzzRacer
Old Jun 22, 2006 | 04:54 PM
pimpberetta's Avatar
pimpberetta
Also works for me and my 95 highline!
Old Jun 23, 2006 | 03:44 AM
dogdaysunrise
and also, what is wrong with OBD-I? My truck is OBD-I and I can hook up my laptop to it with 2 wires and it will tell me everything the truck is doing including fuel curve. It tells me what each sensor is doing. Computers in cars are stupid in my opinion. I will take a good old fashioned smallblock any day.
Old Jun 23, 2006 | 04:27 AM
FuzzRacer's Avatar
FuzzRacer
some computers kick butt, but I know what your getting at though, my friends mom had a rivera not sure the year but it had a comp in it, if the comp went bad then you where screwed and had to buy a new one at a crazy price
Old Jun 29, 2006 | 10:38 PM
rickoh's Avatar
rickoh
https://dodgeforum.com/m_63384/tm.htm
go there for a list of the codes
