2 new problems
Old Jun 23, 2006 | 12:36 PM
Jeanette656's Avatar
Jeanette656
Default 2 new problems
Im having 2 problems with my 96 neon sohc, im not sure if the problems are related because they dont happen at the same time. My first problem is a thumping noise coming from somewhere in the front during quick acceleration, or just having my foot on the gas when I hit a bump it bangs pretty hard, but if I take my foot off the gas over a bumb it doesnt bang.
My second problem is a really bad miss during acceleration at low rpm, I have to gear down to stop the missing. As long as the car is at high rpm it wont miss. Also, when I first start it, it idles really rough until it warms up. My check engine light is on, and I tried to pull the codes, but it wont work. Im at a loss with both problems and not quite sure where to start, any help would be greatley appreciated! Thanks!
Old Jun 23, 2006 | 01:28 PM
das2123's Avatar
das2123
Default RE: 2 new problems
Try pulling the codes again with the on-off-on-off-on trick. It does work, you have to complete the cycle within 5 seconds. Post back with the codes.
I'm guessing one is a Code 43...cylinder misfire.
Old Jun 23, 2006 | 01:43 PM
Jeanette656
Ive tried pulling the codes many times. My manual says to turn the key on , off, on, off, on, then count the number of times the engine light flashes. But mine wont flash! I assumed to turn the key off would be the off position, or should it be the lock position?
Old Jun 23, 2006 | 01:45 PM
das2123's Avatar
das2123
That is correct, but you should bet something...if nothing else you should get a code 55, which means end of codes. Try going somewhere like Autozone, where they do the free scan.
Old Jun 23, 2006 | 02:37 PM
spudsterier's Avatar
spudsterier
the thumping sounds kinda like a tie rod or ball joint, get the front up on jacks and wiggle the wheel, it shouldnt move, but if it moves front to back then its a tie rod, up and down should be a ball joint, and every direction would be a wheel bearing( wheel bearing is easy, when its in the air, spin the tire and see if it grinds)
Old Jun 23, 2006 | 03:39 PM
tomthedog's Avatar
tomthedog
when you turn the key, are you turning it to "run" (just before start) and then one click back to "off" or something else? first time i did it it didn't work for me. good luck.
