Flowmaster 60 Series Kit
Old Jun 23, 2006 | 04:24 PM
darianlow's Avatar
darianlow
Default Flowmaster 60 Series Kit
Anyone actually heard the kit/muffler on a noen, my friend got a muffler for his 91 Tegra and It didnt make a difference, just sounds like a rattle at higher rpms.
Old Jun 23, 2006 | 06:03 PM
das2123's Avatar
das2123
Default RE: Flowmaster 60 Series Kit
Sounds deep and mellow, but that is with upgraded 2.5" piping.
*edit* I was thinking of the Camaro Series muffler. It's cheaper if you upgrade the piping with Dynomax or pacesetter 2.5", then put on the Camaro muffler.
Old Jun 23, 2006 | 07:43 PM
darianlow's Avatar
darianlow
Is stock exhaust 2 1/4" piping?
Old Jun 23, 2006 | 07:52 PM
das2123's Avatar
das2123
ORIGINAL: darianlow
Yep!
Old Jun 24, 2006 | 07:12 AM
darianlow's Avatar
darianlow
Ah yes, I crawled under my car today after I asked
now I just have to find a header that will boltt to my stock exhaust and Cat Converter and such without mods since I dont want to take it to Budget or a muffler shop.
Old Jun 24, 2006 | 12:02 PM
das2123's Avatar
das2123
ORIGINAL: darianlow
Pacesetter and Mopar have ones that bolt up.
Old Jun 24, 2006 | 03:55 PM
darianlow's Avatar
darianlow
What about a Hedman Header?
Old Jun 24, 2006 | 09:01 PM
das2123's Avatar
das2123
ORIGINAL: darianlow
The Hedman is a suitable stock exhaust manifold replacement, but since it has tubes even shorter than the Pacesetter, it makes the least hp of any header available. No direct fit header like the Hedman/Chikara will make much hp over stock since the tubes are so short.
Old Jan 10, 2008 | 10:05 PM
cruisin08avenger's Avatar
cruisin08avenger
I had the flowmaster 80 on my Neon all years and used 2.5 exit piping. It sounds mean at idle and has a great rumble driving, not that rice burner sound. Ill fair warn you it is loud but worth it all.
Muffler plus install will run 125.00 if you get one on ebay then go to a muffler shop.
i have one for sale all ready to weld on if interested. cheap. w. chrome tips.
Old Jan 11, 2008 | 09:23 AM
hatchetman2590's Avatar
hatchetman2590
i have a super 40 series on my neon and even at high rpms it does not sound bad it is always deep and loud and since it is in the same spot the stock one is i have a 24" exhaust tip straight out the side(its a resotipe) and it sticks out about 3 inches
