Engine
Old Jun 24, 2006 | 09:59 PM
95neoncustom's Avatar
95neoncustom
Default Engine
How can i tell if my engine is dohc or sohc
all it says is 2.0 litter 16 valve
Old Jun 24, 2006 | 10:28 PM
das2123's Avatar
das2123
Default RE: Engine
Take off the timing belt cover, 2 cams=DOHC, 1 cam=SOHC. Some people say look at the hood or muffler, but those can easily be swapped out.
Old Jun 25, 2006 | 06:13 AM
Ramrat's Avatar
Ramrat
Default RE: Engine
you can tell by just looking at the timeing cover, the DOHC is much wider and all but one neon I have been under the hood of have said right on the valve coverSOHC or DOHC
Old Jun 25, 2006 | 10:15 AM
spudsterier's Avatar
spudsterier
Default RE: Engine
none of the 2.0 dohc motors i have had ever said it on the valve cover....if it does say, then it would be on the air intake tube, if its a 97 or newer, maybe they started that in 98, i dont remember
Old Jun 25, 2006 | 12:05 PM
das2123's Avatar
das2123
Default RE: Engine
My 99 DOHC doesn't say anything on the valve cover.
Old Jun 25, 2006 | 04:21 PM
rrwertz's Avatar
rrwertz
Default RE: Engine
sohc will say 2.0
dohcs say nothing on the valve cover
Old Jun 25, 2006 | 06:18 PM
das2123's Avatar
das2123
Default RE: Engine
ORIGINAL: rrwertz
sohc will say 2.0
Not all of them.
