Before I go and buy the gauges....
Old Jun 27, 2006 | 04:00 AM
darianlow's Avatar
darianlow
Default Before I go and buy the gauges....
Is there an easy hook up point for an oil pressure and a water temp gauge?
electric or mechanical, where is the tap points, or wires to get the info to the gauges?
Old Jun 27, 2006 | 10:23 AM
spudsterier's Avatar
spudsterier
Default RE: Before I go and buy the gauges....
im not sure where they would be, but its a good thing you asked because im getting gauges today and was gonna ask the same thing
Old Jun 27, 2006 | 12:17 PM
das2123's Avatar
das2123
You should have two ports on the back of the block. See pics below, first two are for the oil...rest are for water!
[IMG]local://upfiles/33897/20A14448C65A448D84C9D7593D623DD0.jpg[/IMG]
[IMG]local://upfiles/33897/1C39212796E045B2BED9CE7CDCB31CAC.gif[/IMG]
[IMG]local://upfiles/33897/27AC486A67714C1AB80DBB5AFB10D407.jpg[/IMG]
[IMG]local://upfiles/33897/9C8DB267663A421DB38B8191DA74F842.jpg[/IMG]
[IMG]local://upfiles/33897/943111451A70497586D17CE5057A6BAD.jpg[/IMG]
Old Jun 30, 2006 | 05:06 AM
darianlow's Avatar
darianlow
What would I need to run electric gauges?
Old Jun 30, 2006 | 11:58 AM
das2123's Avatar
das2123
No.
Old Jun 30, 2006 | 03:59 PM
darianlow's Avatar
darianlow
no? I cant use electric gauges? []
Old Jun 30, 2006 | 04:03 PM
das2123's Avatar
das2123
ORIGINAL: darianlow
I thought you asked if you needed to run electric gauges, not if you could. Yes, you can, no, you don't need to. I have no experience with electrical gauges. I'm sure they come with installation instructions.
