fuel pump fuse blown
Old Jun 27, 2006 | 11:50 AM
dubbz's Avatar
dubbz
Default fuel pump fuse blown
Ongoing problem, 96 Neon shuts down when the fuel pump fuse blows. I put a circuit breaker checker in place of the fuse and it would get very hot prior to shutting down. Searching the board I saw many with the same prob. All the grounds seem to have good contact. All sensors seem fine. Would the crank sensor cause the fuse line to get that hot? Any definitive way to check the fuel pump. Any advice appreciated.
Old Jun 27, 2006 | 12:05 PM
das2123's Avatar
das2123
Default RE: fuel pump fuse blown
Blown fuses=bad grounds. Check grounds and wiring again.
Old Jun 27, 2006 | 04:49 PM
tomthedog's Avatar
tomthedog
pcm also on the same circut, check it as well.
Old Jun 27, 2006 | 10:30 PM
IGottaFreeNeon's Avatar
IGottaFreeNeon
My O2 sensor got burned and the wires fried. That ended up blowing my fuel pump fuse. I just spliced the wires back together, changed the fuse and I was off and running. Hope it helps.
Old Aug 8, 2006 | 12:24 AM
white96neon's Avatar
white96neon
My cars a 96 too and i have the exact problem any one know how to fix ...it rilly sucks cant even take the car far out b4 im stuck some were ..please help runing low on replacement fuses lmao
