My friends neon low compression
Old Jun 27, 2006 | 06:43 PM
HabitatHxC's Avatar
HabitatHxC
Default My friends neon low compression
OOOOk So we have a problem, my friends neon has low compression in the first piston and the third, 60 in 1 and 120 in 3, So we popped the head off, and none of the valves were bent, or blown out, so we started investigating the pistons, this is what we found
That is the 1st piston with the edge missing a little. Im sure that would cause the low compression? Right?
Finnaly, we had an idea from the local neon guy, that you can take The 2.4 bottom end and put the 2.0 sohc Top end on? The neon guy runs the v8 class with his other neon that has the 2.4 bottom end, and the sohc top end. Anyone ever heard of this?
Any imput on this would help us out some! Thanks!
Old Jun 28, 2006 | 06:59 PM
tomthedog's Avatar
tomthedog
Default RE: My friends neon low compression
havn't heard about it. when he says bottom end does he mean just the crankshaft or the whole rotating assy (pistons, rods, and crank)?
Old Jun 28, 2006 | 07:45 PM
HabitatHxC's Avatar
HabitatHxC
Pistons rods crank block the whole shabang!
Old Jun 28, 2006 | 09:12 PM
das2123's Avatar
das2123
I wouldn't think the 2.4 bottom would mate with a SOHC...maybe a DOHC seeing as how the 2.0 and 2.4 DOHC heads are the same.
Old Jun 29, 2006 | 07:12 AM
HabitatHxC's Avatar
HabitatHxC
interesting, we will have to do some more research! Thanks!
Old Jun 29, 2006 | 02:38 PM
tomthedog's Avatar
tomthedog
just a heads up, minus the head and everything bolted to the block is the "short block". keep us posted, would like to hear the build. good luck.
