1 A/C ? 1 General ?
RE: 1 A/C ? 1 General ?
Tighten your power steering belt up...it's probably loose. The rear defrost uses the A/C to help take moisture out of the car as well.
What do you need? All body parts are compatible, 95 and 96 engines have some different sensors, all 97-99 parts are interchangable. Given the same type of engine.
ORIGINAL: mojojojo
I need some misc. parts nothing major...what year neons have compatable (drive train), (body), etc... ? mine is 97'
the power steering belt? how would that affect the noise the A/C and defrost make when its on? are they connected some how? if so wouldn't it make noise when i turn the wheel etc...?
Parts needed are small misc. stuff like air filter lid, head light mount, air bag (driver), a cpl of the vents from the interior. nothin major except the airbag. but i think i found one waiting for a response from a guy.
power steering and a/c on the same belt. some times mine squeals when i make tight turns with the a/c on too, not with the a/c off though. the belt is as tight as i can get it without another set of hands so i just live with the noise or turn off the a/c in park lots.
the a/c also comes on with the defrost, helps it work faster. good luck.
