Need Help Plz
Old Jul 3, 2006 | 03:56 AM
DNeon's Avatar
DNeon
Default Need Help Plz
hey
ok so I bought a 97 Plymouth Neon Coupe MTX, got it for cheap cause it needed new rod bearings...anyway so I'm in the middle of taking out the engine, and I got everything unbolted that sould be unbolted. Motor mounts, transmission, hoses, wiring, accesories...but I cant get the engine to come off the transmission. Is there sumthing connectin it from the flywheel? just to clarify the transmission is still in the car, I dont really wanna take that out, I just want the engine out. o yea one more thing the lil rectangular lite beside the headlites, can I take those off? I've seen Neons witout em.
Old Jul 3, 2006 | 04:11 AM
LilRedNeon97's Avatar
LilRedNeon97
Default RE: Need Help Plz
im pretty sure those lights do come of.... but it may not be leagal. you should check.
Old Jul 3, 2006 | 05:04 AM
dogdaysunrise's Avatar
dogdaysunrise
did you undo the flexplate bolts?
Old Jul 3, 2006 | 05:06 AM
dogdaysunrise
life is a bit easier with the transmission out too. It is kinda a pain in the *** to get the axle shafts out however to pull the transmission
Old Jul 3, 2006 | 05:15 AM
DNeon's Avatar
DNeon
I'm prolly gonna smash my face in after I read the reply to this......but......WTF is a flexplate?????
=( I hope I dint damage anything I tried pryin between the engine an the tranny, liftin the engine while knockin on the tranny like a mad man, moved the engine back an forth.....damn.....this flexplate thing is gonna make me lose sleep tonite....lol
Old Jul 3, 2006 | 05:32 AM
DNeon's Avatar
DNeon
oops...my bad...I dint no ppl called the flywheel a flexplate =x
any tips on how to undo those with a stand under the tranny and a jack under the engine? I dont have an engine hoist...or should I just bolt the top bak up?
thanx for the help DogDay really appreciate it
and the lite thing...I no they can come off, I was jus wonderin if I need them
o yea is it ok if I leave my engine and my tranny on a stand over the nite? considerin everythings pretty much unbolted cept for my flex plate LOL
Old Jul 3, 2006 | 10:02 AM
spudsterier's Avatar
spudsterier
leavin it on a stand wont wurt anything....
the flex plate is different then the flywheel...there is the flywheel, the flexplate, and the clutch disc...
under the motor, you should of removed a thin metal plate, that is between the oil pan and trans...behing that is the clutch assembly....there are 4 bolts that hold that together.....you can rotate the flywheel and reach them all that way...hope it helps
Old Jul 3, 2006 | 12:10 PM
dogdaysunrise
just put the transmission in gear and you should be able to undo the bolts. They are 13mm if i remember right (like most of the stuff on that car)
Old Jul 3, 2006 | 05:13 PM
tomthedog's Avatar
tomthedog
did you pull the starter?
Old Jul 3, 2006 | 11:28 PM
DNeon's Avatar
DNeon
yea I've pulled pretty much erything off.
Thanx alot for the answers guys. I feel like an idiot =\ I'm a second yr apprentice first time doin this on my own tho...not familiar wit manual transmissions.
k so bak to the lite question. do I need those lil rectangular lites??
