Better Gas Mileage?
Old Jul 8, 2006 | 12:51 PM
  #21
das2123's Avatar
das2123
Default RE: Better Gas Mileage?
Toe in or out is what causes your tires to wear unevenly. Camber doesn't so much, but if you have real bad camber like over -1.5 or over +1.5 then maybe I could see.
Old Jul 8, 2006 | 07:05 PM
  #22
1994shadowman's Avatar
1994shadowman
ORIGINAL: das2123
ORIGINAL: 1994shadowman
Theres always buying a higher flowing exhaust system, and a higher flowing air filter. That is usually good for at least 1 mpg.
Generally the amount of money you'll spend on modifing the car in the hopes of better mileage is offset by the cost of the part itself.
If you spend $200 on a thermal muffler, and get 1mpg better. You'll have to drive over 100,000 miles just to break even on the cost of gas.
das, I just meant a $20 glasspack or turbo muffler Or better yet get a $20 fart can from NAPA [8D]
