silly ? spark Plugs
#21
RE: silly ? spark Plugs
msd are red and 8mm
if you dont have a plug socket to remove the plugs then you can get them loose with a regular socket...then stick the plug wire back on them...spin it a few times and pull the plug wire out and the plug will still be stuck on there...same thing for install....just make sure to only use the wire to get the plug started if you go this route...so that you dont spin the little cap off the plug...i did it this way for years....until i realized there was a socket used for removing them
#22
ORIGINAL: LilRedNeon97
hey, i have to change my spark lug wires too. But i want the red ones. where can i get them and what brands should i be looking for. i dont want crap, ya know...
http://www.modernperformance.com/dcx/msd_8.shtml
Magnecor
http://www.modernperformance.com/dcx/nemagne.shtml
I have the Magnecor 8.5mm wires and they work great.
