HG Confusion?
Old Jul 6, 2006 | 05:34 PM
Chris2121's Avatar
Chris2121
Default HG Confusion?
Some might know that i have a 97 Sohc. I took out the engine to replace it with a newer engine (trouble free). I just looked over the parts, and i noticed that the hg was replaced with a mls. My mother took it to the dealer about 1 year ago. The hole reason we planned to change engines was because of the hg. Just some info, if you have a mls, dont think it will be trouble free. Right before we took it out, my father and i did a compression test, and it came up very low. 90 and even one was at 40. Just a word of advice, the mls isn't as good as some say.
Old Jul 6, 2006 | 05:43 PM
NEONRT98's Avatar
NEONRT98
Default RE: HG Confusion?
Perhaps not, but they are way better than what Dodge/Plymouth/Chrysler put in their beginning lines of the Neon.. I have a 98 Neon w/ the MLS (Checked when I took off the intake manifold) and I have yet to run into any problems, still runs like a champ w/ 187k miles on it.. Though I do beleive it may have been either rebuilt or the HG changed and one point in time.. But any car you beat the **** out of will blow a headgasket..
Old Jul 6, 2006 | 05:46 PM
Chris2121's Avatar
Chris2121
it was my mothers car, she drives very slow, never beat on it, she never took it over 60mph. But i did when i was 14. I had it up to 95 and it would not go any faster.
Neon Rt, what engine do you have in your car. Im looking to get a 2nd gen engine, and don't know what to get. I might get lucky at the junkyard and find a good one.
Old Jul 6, 2006 | 05:53 PM
das2123's Avatar
das2123
How did you confirm the HG was the cause for the low compression? There are lots of things that can cause low compression. The MLS gasket is a great quality piece.
NEONRT98, has an R/T, so he would have a DOHC engine in there, unless he swapped it out.
Old Jul 6, 2006 | 06:10 PM
Chris2121's Avatar
Chris2121
its 3 layers of steel. It has a rectangle kinda tab on one side, and 2 smaller circle looking tabs also. It was leaking a little oil, but that wasnt the entire problem, the piston rings were shot too. The top of the pistons were black.
I was thinking about trying to get a sohc motor, it has to be 2nd gen, i dont want problems. Also has to fit in a 1st gen without many problems. An 02 sohc will fit, all i have to do is change the sensors.
Also das can you answer my window clip problem
Old Jul 6, 2006 | 06:17 PM
das2123's Avatar
das2123
I don't know anything about the window clips, sorry!
Any SOHC motor with the MLS should be fine. I can understand wanting to go with a newer motor, but you don't have to.
Old Jul 6, 2006 | 06:35 PM
DNeon's Avatar
DNeon
wats a MLS?
Old Jul 6, 2006 | 06:45 PM
Chris2121's Avatar
Chris2121
multi layer steel (its better)
I called a junkyard and they have an 02 sohc, im gonna get that, but i might get lucky and its a magnum
das2123's Avatar
das2123
ORIGINAL: DNeon
wats a MLS?
Multi-Layered Steel headgasket.
*edit* Doh, Chris2121, beat me to it
Old Jul 6, 2006 | 06:46 PM
Chris2121's Avatar
Chris2121
its not window clips, its for the crank on the window. It doesnt stay on. And i dont know how the clips go on
By 10 seconds too, lol
