Headlights?
Old Jul 7, 2006 | 06:43 PM
LilRedNeon97's Avatar
LilRedNeon97
Default Headlights?
Is changing the headlight assembly a difficult task? or are they basically remove and replace?!?i was thinking about getting a new pair since theyre so damn foggy!! but i dont want to get ripped off at some place for labor!! especially if i can do it myself!
Thanks!
Old Jul 8, 2006 | 05:08 AM
FuzzRacer's Avatar
FuzzRacer
Default RE: Headlights?
changing the headlight assembly isn't hard at all, it just takes some time and patience. I say that only because of the room to work with while you unscrew the screws then depending on what kind you get you might need to adjust them for better seeing, which isn't hard either very easy to do. if you don't want to go that route you could look into cleaning them and instead, that way you would save some money hope that was helpfull and good luck !!
Old Jul 8, 2006 | 07:33 AM
LilRedNeon97
yeah, i "CLEANED" them already. i bought some stuff to clean them. it took the yellowness out of the lens, but nothing will get rid of that fog! and i hate always wanting to (and mostly do) drive around with the brights on at night!
Old Jul 8, 2006 | 03:03 PM
das2123's Avatar
das2123
2 10 mm bolts up top and one behind the headlight on the fender and remove the turn signal flashers and you are good to go. The one behind the headlight can be reached with an extension or you can get on the ground and look up to reach it. I have the Diamond Clears on my neon and love the way they look...
http://www.modernperformance.com/dcx..._1995-99.shtml
