A Cam will give you HP, but you should also get a cam gear to help tune it...although not necessary. You will need to upgrade your springs if you get an aftermarket cam.
Since you are going to spend all the money on a new can and adjustable timing gear, I would suggest getting the engine section of the service manual(if it is in different books) or just the whole thing, They are only around $120 CAD.
