Valve cover gasket, spark plug tube seals
Old Jul 19, 2006 | 03:01 AM
Allnbrgdn's Avatar
Allnbrgdn
Default RE: Valve cover gasket, spark plug tube seals
I really need the info!! Im doing a bunch of work myself out of a book, so as many tips as possible please.
Old Jul 19, 2006 | 03:48 AM
das2123's Avatar
das2123
There could be alot of reasons for your car being sluggish, but this could be one. Your car overheating, should not be related. Check your thermostat, radiator cap, and even your radiator.
Old Jul 20, 2006 | 02:19 AM
Allnbrgdn's Avatar
Allnbrgdn
the only thing i havent done is replaced my radiator, do you think i should put rtv on the spark plug tube seals also ?
Old Jul 20, 2006 | 02:31 AM
das2123's Avatar
das2123
ORIGINAL: Allnbrgdn
NO!
Old Jul 20, 2006 | 02:37 AM
Allnbrgdn's Avatar
Allnbrgdn
glad i asked
Old Jul 20, 2006 | 09:07 AM
neon.ace's Avatar
neon.ace
Hey everyone with that RTV sealent does it need to det up without the engine being ran for a full 24 hours? Can you immediately begin driving again? I did not quite understand that listed on the instuctions and this sealant is going to be critical not only for me but, for my friends integra. thanks
Old Jul 20, 2006 | 02:17 PM
pimpberetta's Avatar
pimpberetta
I would guess maybe theres instructions on the can or bottle of what your using, does it not say how long it should be sitting for?
Old Jul 20, 2006 | 04:38 PM
Allnbrgdn's Avatar
Allnbrgdn
well I replaced the gaskets and it seems to run fine! when i got home i raised the hood to inspect for leaks and noticed a little bit of smoke on the left side of the valve cover, is this normal ?
Old Jul 20, 2006 | 07:05 PM
Allnbrgdn's Avatar
Allnbrgdn
I think it was the RTV, I took it for another test drive and now its not smoking
Old Jul 23, 2006 | 10:44 AM
neon.ace's Avatar
neon.ace
The instrustions on the RTV sealant says to let the sealant sit for a full 24 hours before driving it. I think that is if you are using it on a critical engine part. I would just be using it on the vavle cover gasket. Do I really need it on the valve cover gasket? I have a good gasket on the valve cover and I took it off not to long ago, used not RTV, and I have not seen any oil around the cover since. So with that in mind do you all really think I need to use it again on the vavle cover?
peace and quail grease
