gauges......I know
Old Jul 31, 2006 | 08:26 PM
  #31
Allnbrgdn's Avatar
Allnbrgdn
Default RE: gauges......I know
Please help!
Old Aug 1, 2006 | 12:57 AM
  #32
Allnbrgdn's Avatar
Allnbrgdn
It has to be the Instrument cluster, if anybody can help i would greatly apreciate it!! I already had a buddy re-solder them and all work but the speedometer and the odometer, unless I press on the gauges will driving, but then other things pop on, do you think I should re-solder them again or buy a new cluster ? any suggestions please ?
Old Aug 1, 2006 | 01:07 AM
  #33
das2123's Avatar
das2123
Get a new one!
Old Aug 1, 2006 | 06:27 PM
  #34
Allnbrgdn's Avatar
Allnbrgdn
thanks
Old Aug 12, 2006 | 07:06 PM
  #35
mached's Avatar
mached
I had the same problem of speedometer acting up all over the place and my problem was the slide thru connectors.Apparently they were not fitting well so I just tightened the plates and haven't had the problem again.
Old Aug 12, 2006 | 07:31 PM
  #36
Allnbrgdn's Avatar
Allnbrgdn
does anybody know where i can find a cheap instrument cluster brand new for a 97' dodge neon dohc no tach ?
Old Aug 12, 2006 | 08:36 PM
  #37
das2123's Avatar
das2123
ORIGINAL: Allnbrgdn
I don't know where you can get a new one, but you can get used ones from Ebay pretty cheap. Why not get one with a tach for like $50 used? If you need one, PM me.
Old Aug 12, 2006 | 10:33 PM
  #38
Allnbrgdn's Avatar
Allnbrgdn
how do u PM ?
