Fuel Injector o-rings?
Old Jul 18, 2006 | 08:37 PM
Bassboy's Avatar
Bassboy
Default Fuel Injector o-rings?
What all is involved in changing them? my #2 and #4 cylinder injectors are leakin a bit and I bought new o-rings for all 4 but am unsure how exactly to change them. I know you need to depressurize the fuel line, then remove it do the injectors just pull out?
Old Jul 18, 2006 | 09:27 PM
spudsterier's Avatar
spudsterier
Default RE: Fuel Injector o-rings?
ok so yeah....use a screwdriver and release the pressure....then remove the two bolts that hold down the fuel rail....if its the o rings that are on the top of the injector that go into the rail then you have to remove the retaining clips with a screwdriver or pliers....if its the o rings on the bottom of the injects then remove the injectors the same way....but you dont have to reomve the injectors from the rail
i use a screwdriver to pry the whole rail and injectors out of the intake manifold then remove it all from there....
and remember to disconnect the wire clips first...that way you have more room
hope this isnt too confusing
Old Jul 18, 2006 | 09:29 PM
Bassboy's Avatar
Bassboy
Nope explains it perfectly, yea its the ones on end by the intake not the fuel rail.. hopefully thats the o-rings they gave me, or they are the same orings lol..
Old Jul 19, 2006 | 01:57 AM
spudsterier
as far as i remember, they are the same thing
Old Jul 19, 2006 | 09:05 AM
Bassboy's Avatar
Bassboy
Got them all changed before I went into work lastnite, tho I lost one of the bolts for the fuel rail and had to walk to Napa to pick up another lol.. Thanks for your help bro was very easy to change them.. the 2 that were leaking were so warn out its not even funny..
