SOHC Block?
Old Jul 21, 2006 | 08:48 PM
DNeon's Avatar
DNeon
Default SOHC Block?
My car is originally DOHC, I need a new engine...an SOHC seem to b cheaper so I'm wonderin if I could get a SOHC engine an throw my DOHC heads on it. do I need to change anything? I heard I would have to do a few things to make it work...
Old Jul 21, 2006 | 08:52 PM
neon2_0t's Avatar
neon2_0t
Default RE: SOHC Block?
if your going to do that just get a 2.0L block and install all your components from the dohc on it both the sohc and the dohc share the same block.
Old Jul 21, 2006 | 09:19 PM
DNeon's Avatar
DNeon
I've called TONS of places around here...nobody sells only the block. they all told me I had to buy the whole engine assembly.
Old Jul 22, 2006 | 02:13 AM
dogdaysunrise's Avatar
dogdaysunrise
junkyard would be your best bet.
The pistons are slightly diffrent on the DOHC though. They have some little pockets in them. I heard if you use the sohc pistons with a dohc head your compression goes in the crapper.
Where do you live? I do have a sohc block sitting on a stand that I might be looking to part with.
Old Jul 22, 2006 | 03:58 AM
DNeon's Avatar
DNeon
is that it? jus the pistons? cause I wanted new pistons anyway.
my old engine had 95 000 on it...I dunno how the guy screwed it up. needed new rod bearings. when I got it to the machinist he showed me the pistons...tol me I would need to bored out the cylinders. all the pistons was scratched up on the skirt. I also needed new oil pump, an crankshaft. which altogether would cost me 1800. which I dun wanna spend on a new engine. so if I could jus get a block an get new internals....I dunno =(
