performance pcm question
Old Jul 22, 2006 | 01:09 AM
spudsterier's Avatar
spudsterier
Default performance pcm question
i am wanting to get one here real soon...but which would be better? the mopar performance or the AFX???
does anyone know the differences???besides the price...
if i remeber, the AFX lets you remove the downstream o2 sensor without a check engine light...but what about the mp??
how about the egr???
i just wanna know some advantages or disadvantages
what about the afx street/strip or race???
can i use these with a turbo or not????
Old Sep 21, 2006 | 04:17 PM
das2123's Avatar
das2123
Default RE: performance pcm question
I didn't see this post when it came around and I know its a bit old, but this is a good question. So I will answer it now.
The AF/x PCM is better than the Mopar, thus the cost. The AF/x PCM doesn't look at the downstream O2 sensor, but the Mopar PCM does. Neither look at the EGR system. You can use either with a turbo, but you must use an adjustable cam gear or some other means of retarding timing since both advance the timing, which is a BIG NO-NO on a turbo engine.
Old Sep 21, 2006 | 04:24 PM
JDC420's Avatar
JDC420
An adjustable cam gear wont work because the ECU is adjusting the spark timing, and the cam gear is affecting to camshaft timing. You would still have advanced spark. Are there any piggyback ECU's or anything to use for this?
Old Sep 21, 2006 | 04:31 PM
das2123's Avatar
das2123
My bad, not the cam gear but you would need an MSD-DIS2 programmable shoule be used if you want to use an aftermarket PCM.
spudsterier
well geez......its about time
Old Sep 21, 2006 | 04:36 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
Sorry . I was going through some of the posts and ran across it.
Old Sep 21, 2006 | 04:43 PM
JDC420's Avatar
JDC420
At least you replied exactly 2 months after the original post, on the 21st.
Old Sep 21, 2006 | 07:46 PM
spudsterier
to bad it isnt really important anymore.....since im just gonna have the turbo and nitrous...
i just bought my intercooler.....65.00 shipped
so im getting a few steps closer
Old Sep 22, 2006 | 02:12 AM
xdeathwishx's Avatar
xdeathwishx
so if i want to increase my redline, and have a turbo, what all do I need? the aftermarket pcm and this MSD-DIS2 thing?
