still having problems HELP!
Old Jul 22, 2006 | 05:56 PM
MyDarkestSin's Avatar
MyDarkestSin
Default still having problems HELP!
Upon further inspection I resolved the touchy throttle in this 97 SOHC. I cleaned the PCV valve and it isn't jumping when I only lightly touch the gas. The check engine light went out for about 4 miles only to come back on. I checked it again and got the same code ( ENG: 51/p0171 fuel sys 1/1 lean). The thing is it's not running funny at all except a louder idle, not faster or slower just louder. Anyone have suggestions?????????
Old Jul 22, 2006 | 06:06 PM
tomthedog's Avatar
tomthedog
Default RE: still having problems HELP!
the pcv is a REAL cheap part to replace ($5-10). do you mean the EGR valve that is on the right hand side of the block as you look at the eng when the hood is open?
Old Jul 22, 2006 | 06:07 PM
NEONRT98's Avatar
NEONRT98
How many other people have had the car before you..? Could be that the TB was upgraded and you dont know about it
EDIT: a larger TB (More than 52mm) will cause your engine to throw a "too lean" code.
Old Jul 22, 2006 | 06:23 PM
tomthedog's Avatar
tomthedog
DANG, gotta stop drinking. N-98 has a GOOD point. it's a good idea to start a new thread with your eng/trans/mods info. if you have what you think to be a touchy throttle, by what ref are you going by? i know it's not a 1915 model T. but we all need more info. let us know.
