overheating
RE: overheating
Check over your radiator for any damaged fins or anything physically. I took mine out and flushed it out and found that about 50% of my fins just fell right out of it when I was rinsing off the front.. They are copper cores and rot out and deteriorate like any other part on a car. Another thing, check to see if your fans are running when you have your A/C on. They should be running the whole time your A/C is on. If not, check your relays again.
RE: overheating
Usually if its the coolant sensor, you get lower readings, I beleive..
Physically take out your radiator and check over it, make sure the fins are secure in there. I just had to replace mine being the fins fell through when I pushed on them.. thats not supposed to happen, haha
RE: overheating
sounds like it....i need to replace mine this weekend...all the fins in the bottom left corner were just gone....about a 7inch by 8inch section is gone....
my wifes neon overheats when the a/c is on too...so a radiator for that is on the list soon too
you could also remove the fan/fans...loosen the horizontal bolts ontop or the radiator...then pull up the fans and disconnect the wire connectors....once the fans are outta the way you will clearly see if thats the problem
Trending Topics
RE: overheating
when you run the a/c, it takes the heat from the inside and leaves it right in front of your rad (the condense core). if your "fins" are jacked you can get a "fin comb" at the parts store to put them right. or you can use a kitchen butter knife (takes longer but better results). your eng rad is more critical wich is why it's behinde the condensor core. good luck.
