srt4 swap 98 neon
Old Jul 24, 2006 | 03:59 PM
98srt4screamer's Avatar
98srt4screamer
Default srt4 swap 98 neon
im swapping a 2004 srt4 engine in my 98 neon im using my first gen tranny with a new clutch an flywheel, i know i need mounts, harnesses, stage 1, and cluster. alright will the 2nd gen cluster swap out with the first gen? and where can i get 2.4l motor mounts not srt4 mounts and how much will they be? and what harnesses do i have to get (dash, engine, both?) and will they swap out or do i have to splice them in with mine? what kind of clutch should i buy all the clutches for my tranny are n/t so can i use a n/t clutch on the srt4 engine? if im missing anything i would need to do the swap tell me. i appriciate any help with any of these questions, tim
Old Jul 26, 2006 | 06:09 AM
99SRT4's Avatar
99SRT4
Default RE: srt4 swap 98 neon
i am in the middle of the swap i made my own motor mounts the front mount u have to cut out 4 the oil pan and the passenger side u can make like i did https://dodgeforum.com/m_491087/tm.htm and the tranny 1 turn up side down and u have to use the engine bay harness, the dash harness
