PCM Question? ACR-AF/X-Mopar Performance??
Old Jul 27, 2006 | 11:53 PM
NYG's Avatar
NYG
Default PCM Question? ACR-AF/X-Mopar Performance??
I have read about the AF/X and the Mopar Performance PCM doing a search on here:
Basically what I have read - if you have alot of Mods - you would probably get more out of a AF/X over the Mopar Performance.
This is comparing the AF/X racing version over the street version.
What I could not find is - what is the difference between a ACR PCM and a Mopar Performance PCM?
I race a factory stock DOHC engine with a 5 Speed Manual.
Would like to hear feedback from others Neon Drivers experiences with the different PCM's
Old Jul 28, 2006 | 02:32 AM
das2123's Avatar
das2123
Default RE: PCM Question? ACR-AF/X-Mopar Performance??
ORIGINAL: NYG
About 8-11 hp because the Mopar PCM advances the timing and fuel curves. It also raises the rev limiter to 7600 on the DOHC.
Old Jul 28, 2006 | 11:10 PM
NYG's Avatar
NYG
Thanks das2123 for the info
Looks like factory stock engines should stay with the ACR PCM or the Mopar Performance PCM (if the rules allow for it)
I PM'ed you!
Thanks
Old Jul 31, 2006 | 06:07 AM
jt98r/t's Avatar
jt98r/t
i personally like mopar pcm alot better!! i think it pretty much gives u the same results...but for less price!!! with a good header n a better flowing intake ive seen an expresso do 15.4 at the track with the mopar ecu!
Old Jul 31, 2006 | 11:03 AM
das2123's Avatar
das2123
Make no mistake about it, the Mopar is great but the AF/x Race version PCM in better. Not much of a difference between the Mopar and AF/x street/strip version. Here is some info from Keith96DOHC:
The '98 DOHC ACR used for the Mopar Action PCM test was stock, except for an Iceman CAI.
1/4 mile times were:
15.21 sec - stock PCM
15.04 sec - Mopar PCM
14.93 sec - AFX S/S PCM
Dyno results were:
131.2 hp stock PCM
138.6 hp Mopar PCM
141.8 hp AFX S/S PCM
Old Aug 12, 2006 | 02:13 AM
rrwertz's Avatar
rrwertz
afx is the way to go, but be willing to spend a little more. I'd only run a stock computer if I was running nitrous.
